  4. VBA, . NET & IRX
Vectorization Failed
  4. VBA, . NET & IRX
DenisSilveira
DenisSilveira
Sun May 24, 2020 8:22 am
#1 by DenisSilveira
I got "vectorizantio failed" error to initiate CMS. Not using VBNET or else.
Is there any upgrade to do ? version 10.0.1110.116340.PE+.VC15.x64.CMS100
  • Mon Nov 02, 2020 10:59 am
CMS Inc
Site Admin
Wed Feb 23, 2005 12:01 am
Azle, TX
  • Facebook
  • Twitter
  • YouTube
Re: Vectorization Failed
#2 by CMS Inc
Check for updates at the CMS IntelliCAD 10 HELP > check for updates feature.
  • Mon Nov 02, 2020 5:40 pm
DenisSilveira
DenisSilveira
#3 by DenisSilveira
Message: "You have the latest version !"
  • Sat Nov 21, 2020 7:43 pm
QuanNguyen
Sat Nov 09, 2019 6:50 pm
#4 by QuanNguyen
Yes, the latest version: 10.0.1118.116743.PE+.VC15.x64.CMS100.
  • Sun Nov 22, 2020 8:11 am
DenisSilveira
DenisSilveira
#5 by DenisSilveira
that's it 10.0.1118.116743.PE+.VC15.x64.CMS100
  • Sun Nov 22, 2020 10:22 pm
CMS Inc
Site Admin
Azle, TX
  • Facebook
  • Twitter
  • YouTube
#6 by CMS Inc
Go to the CMS IntelliCAD HELP Menu and CHECK for UPDATES.
Also try to switch graphics engine at CMS IntelliCAD from OpenGL ES to OpenGL. Your graphics card may require that.
  • Thu Apr 15, 2021 5:20 am
DenisSilveira
DenisSilveira
#7 by DenisSilveira
On check for updates I got an Error Message from server obtaining the CMS Icad Version.
Using Intermediate Open Gl works fine ... until now...
Unsing checked Anti_alising (don1t know what it is for).
  • Sat Apr 17, 2021 6:48 pm
Return to “VBA, . NET & IRX”
  • It is currently Sun Oct 11, 2026 5:19 pm
