Block swap?
I'm working on a drawing I received from another company and there are thousands of blocks that I believe were from Civil 3D point labels. I'd like to replace all of them in one go with the standard block my company uses. Does IntelliCAD have a command that will allow me to easily swap all of those blocks?
Re: Block swap?
I'm not aware of anything in Intellicad that will do what you want.
Others may no better.
If I were face with this issue I would create a 'DXF' file of the drawing, then edit that with Notepad using 'Find' & 'Replace'
You will need to do that for each block name, then re-import back into Intellicad.
I'm sure it could be done via Lisp, but beyond my skill set atm.
Re-reading your post, do you want to replace ALL of the blocks in the drawing with just a single block?
Are all of the blocks on one layer? or could they be (easily).
You can delete a layer and ALL objects on that layer, then insert your company block.
That could be done via a simple script/batch file if there are many to do.
Steve.
Re: Block swap?
sln8458 wrote: ↑
Tue Oct 06, 2020 12:46 am
Steve.
Thank you for your reply, it wasn't every block in the drawing, just the ones that are the wrong symbol for spot elevations. I tried to edit the block, but it was an anonymous block or something like that and wouldn't allow me to edit it. I think every one of them had a different name and I know when exploding Civil 3D labels that is what happens. They are all on the same layer, but all have different names. I did find an easy way to do it though. Apparently the company I work for has AutoCAD 2004 on my machine and I was able to use it to replace all of the blocks using a lisp. Unfortunately that same lisp doesn't work in Intellicad for some reason.
Re: Block swap?
Try to use this lisp, please.
(DEFUN C:ReplaceBlock( / ss ssl new_BlockName index e ass)
 (setq ss (ssget))
 (prompt"\nReplacement block name (block must exist in drawing): ")
 (setq new_BlockName (getstring t))
 (setq ssl(sslength ss))
 (setq index 0)
 (repeat ssl
  (setq e (entget(ssname ss index)))
  (setq ass (assoc 2 e))
  (setq e (subst (cons 2 new_BlockName) ass e))
  (entmod e)
  (setq index (+ 1 index))
 (command "regen" "" )
 (princ)
