  4. New User
new user prerequisites question for CMS IntelliCAD 9.1/9.2 PE
  4. New User
sidecar5
sidecar5
Thu Jul 16, 2020 9:26 pm
#1 by sidecar5
I purchased CMS IntelliCAD 9.1/9.2 PE today and at the download page it says:
Prerequisites:
1) Artisan for IntelliCAD rendering software
2) GEO Coordinate System Dictionaries
Do I take that to mean I need to install those 2 modules before I install IntelliCAD?? Thanks.
  • Mon Jul 20, 2020 1:57 am
sidecar5
sidecar5
Re: new user prerequisites question for CMS IntelliCAD 9.1/9.2 PE
#2 by sidecar5
I have just been advise that IntelliCAD does not require the prerequisites as indicated on page https://www.intellicadms.com/download/f ... -92-pe-x64
  • Tue Jul 21, 2020 4:28 pm
Return to “New User”
  • It is currently Sun Oct 11, 2026 8:34 am
