I need a Leader with an user annotative block. Is there a way to create Annotative Blocks ?
Inside block editor I couldn't find this option.
Re: Block Annotative
#2The way I do this, with item bubbles for general assemblies is:
1/ create a new drawing for my 'bubble'. (draw the circle)
2/ in the circle insert an 'attribute' (define attribute).
When this block is inserted into a drawing you can then edit the attribute to a value of your choosing.
To insert this block with a leader line I have created a toobar with a icon for this.
The command structure to insert the bubble and leader is:
^C^C^C_attdia;off;-insert;bubble;nea;\(getvar "dimscale");;;;_leader;nea;\per;\;;n;attdia;on;
Here is an image to give you an idea of what this all looks like in reality. Now the block can be whatever you need.
HTH
HTH
#3Thanks, I will try that !!sln8458 wrote: ↑Wed May 27, 2020 3:32 amThe way I do this, with item bubbles for general assemblies is:
HTH
