  4. VBA, . NET & IRX
Enable disable custom ribbon buttons
  4. VBA, . NET & IRX
geza.szabo
geza.szabo
Sun Dec 08, 2019 10:51 pm
#1 by geza.szabo
We are adding custom Ribbon buttons into the Default.CUI file. Is is possible to enable/disable these buttons from the .Net API? How?
Kind regards
Geza
  • Fri May 08, 2020 1:58 am
Return to “VBA, . NET & IRX”
  • It is currently Sun Oct 11, 2026 4:40 pm
