I am using a complex Usercontrol in a palletset. When attempting to use keyboard input in my control, keystrokes go straight to IntelliCad comand line.
How do I control this focus?
Re: .net Keyboard Input Focus
#2It's difficult to diagnose what happened with your summary descriptor (by text only).
It's better if have some code to debug.
Regards.
Regards.
#3I have since found that if I hide the Command bar then my editing works correctly but when reOpend the problem reoccurs.
When using PalliateSet in Autocad this problem is not occuring.
#4I got same problema and still didn´t get the solution for this case
#5I've made some tests and observed when I call <commandMethod> to invoke a UserControl inside palletteset some textBox fields doesn't work ... simple the text typed vanissh from screen ...DenisSilveira wrote: ↑Wed Dec 16, 2020 11:08 amI got same problema and still didn´t get the solution for this case
In other hand, when this same pallette set is called from inside a menuContext on form it works fine.
So, I detected the problem occurs when we call <CommandMethod>
#6Hi Denis,
Inside the PaletteSet, try to use the IntelliCAD.Internal.Utils.ExecuteCommand instead of CommandMethod.
#7This time, I used to invoke palleteSet/User control by menu command inside WindosForm, that works normally !!!QuanNguyen wrote: ↑Tue Mar 30, 2021 11:40 pmHi Denis,
Calling commandLine a <CommandMethod>Sub ... constructs the palletset but dosn't work properlly.
