I'm getting an error when i try to update the textstring property of a mtext entity. The problem consists of the fact that the program closes it unexpectedly
Here's the code
With text entity there's no problem.
Anyone knows what's the problem?
dim prefijo as string
dim ttext as intellicad.text
dim tmtext as intellicad.mtext
dim ssset as intellicad.selectionset
set ssset=intellicad.activedocument.selectionsets.add("prueba")
ssset.SelectOnScreen
ssset.Highlight True
prefijo = "prefijo "
For a = 0 To ssset.count - 1
If UCase$(ssset.Item(a).EntityName) = "TEXT" Then
Set ttext = ssset.Item(a)
ttext.TextString = prefijo+ ttext.TextString
ttext.Update
Else
If UCase$(ssset.Item(a).EntityName) = "MTEXT" Then
Set TMTEXT = ssset.Item(a)
TMTEXT.TextString = prefijo+ TMTEXT.TextString 'here occurs the error
TMTEXT.Update
Else
msgbox "Elemento seleccionado deber ser TEXT o MTEXT"
End If
End If
Next
ssset.Highlight False
ssset.Delete
Re: error trying to update mtext.textstring
#2Hi GUILLERMO,
FYI, the latest version works well when updating the content of MText.
