error trying to update mtext.textstring
Posted: Thu Apr 02, 2020 9:08 pm
I'm getting an error when i try to update the textstring property of a mtext entity. The problem consists of the fact that the program closes it unexpectedly
Here's the code
With text entity there's no problem.
Anyone knows what's the problem?
dim prefijo as string
dim ttext as intellicad.text
dim tmtext as intellicad.mtext
dim ssset as intellicad.selectionset
set ssset=intellicad.activedocument.selectionsets.add("prueba")
ssset.SelectOnScreen
ssset.Highlight True
prefijo = "prefijo "
For a = 0 To ssset.count - 1
If UCase$(ssset.Item(a).EntityName) = "TEXT" Then
Set ttext = ssset.Item(a)
ttext.TextString = prefijo+ ttext.TextString
ttext.Update
Else
If UCase$(ssset.Item(a).EntityName) = "MTEXT" Then
Set TMTEXT = ssset.Item(a)
TMTEXT.TextString = prefijo+ TMTEXT.TextString 'here occurs the error
TMTEXT.Update
Else
msgbox "Elemento seleccionado deber ser TEXT o MTEXT"
Next
ssset.Highlight False
ssset.Delete
Here's the code
ttext.Update
Else
TMTEXT.Update
Else
Next
ssset.Delete
