multi-leader has begun to work poorly
Posted: Mon Mar 23, 2020 6:59 am
by slit_ok
Hi there!
With the release of Release 9.2a, construction of the multi-leader has begun to work poorly. after each build of the multi-leader you have to go to the manager and edit the style. there was no such problem before 9.2a. this is a situation where the scale is not 1
Re: multi-leader has begun to work poorly
Posted: Mon Jun 01, 2020 11:21 am
by DenisSilveira
Left is after use PROPERTIES panel and set Block Scale to 1.0
Right is before use PROPERTIES panel, just after insert MLEADER with block.
Seems not to work so good.
Also need to know if I messed something.
Posted: Thu Jun 04, 2020 11:43 am
by DenisSilveira
Anybody else got this problem to solve ?
