  4. VBA, . NET & IRX
No ObjectModified calls when changing property value in property list box
  4. VBA, . NET & IRX
geza.szabo
geza.szabo
Sun Dec 08, 2019 10:51 pm
#1 by geza.szabo
Hi, I am trying to get notifications if the user changes properties of any entity.
I have added a handler to document.Database.ObjectModified but it does not get called if the user changes a property in the property box. How could I make this work?
Kind regards
Geza
  • Mon Feb 17, 2020 8:56 pm
geza.szabo
geza.szabo
Re: No ObjectModified calls when changing property value in property list box
#2 by geza.szabo
I have been testing this further and now it is working. Maybe it was a problem with my code.
  • Tue Feb 18, 2020 4:03 pm
Return to “VBA, . NET & IRX”
  • It is currently Sun Oct 11, 2026 4:40 pm
