Setting up Tool Palettes
I am trying to setup new Tool Palettes and dragging drawing features does not work. Also, copying and pasting commands does not work. When I right click the in Tool Palette box, I can create a new palette but nothing else and there is no way to add commands or or drawing features. So how can new Tool Palettes with custom features be created?
Thanks!
Re: Setting up Tool Palettes
You can add commands at tool palettes by right clicking on top of the tool palette commands area and by selecting "customize commands".
Then you can drag-&-drop an existing tool/command in to the tool palette.
To customize the command, right-click on top of the tool and select "properties". At that point, just edit the command name according to requirements.
