Lisp for Reducing vertices in polyline
Posted: Wed Nov 06, 2019 11:44 pm
by Vik12
I want a lisp routine to reduce the vertices in the polyline. In short I want to simplify the poyline. I used Pldiet lisp in Autocad which worked fine in it. But in IntelliCad it can be used only for polylines containing less than 1000 vertices. IntelliCad crashes if the vertices are more than 1000. Maximum it went till 2000 vertices,I have a polyline with 5000 vertices and it crashes in IntelliCad but works fine in Autocad
This following is the code of Pldiet lisp
;;;  PLDIET.lsp [command name: PLD]
;;;  To put lightweight PolyLines on a DIET (remove excess vertices); usually
;;;    used for contours with too many too-closely-spaced vertices.
;;;  Concept from PVD routine [posted on AutoCAD Customization Discussion
;;;    Group by oompa_l, July 2009] by Brian Hailey, added to by CAB, and
;;;    WEED and WEED2 routines by Skyler Mills at Cadalyst CAD Tips [older
;;;    routines for "heavy" Polylines that won't work on newer lightweight ones];
;;;    simplified in entity data list processing, and enhanced in other ways [error
;;;    handling, default values, join collinear segments beyond max. distance,
;;;    limit to current space/tab, account for change in direction across 0 degrees,
;;;    option to keep or eliminate arc segments] by Kent Cooper, August 2009.
(defun C:PLD
  (/ *error* cmde disttemp cidtemp arctemp plinc plsel pldata
  ucschanged front 10to42 vinc verts vert1 vert2 vert3)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort"))
      (princ (strcat "\nError: " errmsg))
    ); end if
    (if ucschanged (command "_.ucs" "_prev"))
      ; ^ i.e. don't go back unless routine reached UCS change but didn't change back
    (command "_.undo" "_end")
    (setvar 'cmdecho cmde)
  ); end defun - *error*
  (setq cmde (getvar 'cmdecho))
  (setvar 'cmdecho 0)
  (command "_.undo" "_begin")
  (setq
    disttemp
      (getdist
        (strcat
          "\nMaximum distance between non-collinear vertices to straighten"
          (if *distmax* (strcat " <" (rtos *distmax* 2 2) ">") ""); default only if not first use
        ); end strcat
      ); end getdist & disttemp
    *distmax*
      (cond
        (disttemp); user entered number or picked distance
        (T *distmax*); otherwise, user hit Enter - keep value
      ); end cond & *distmax*
    cidtemp
      (getangle
        (strcat
          "\nMaximum change in direction to straighten"
          (strcat ; offer prior choice if not first use; otherwise 15 degrees
            (if *cidmax* (angtos *cidmax*) (angtos (/ pi 12)))
          ); end strcat
        ); end strcat
      ); end getdist & cidtemp
    *cidmax*
      (cond
        (cidtemp); user entered number or picked angle
        (*cidmax*); Enter with prior value set - use that
        (T (/ pi 12)); otherwise [Enter on first use] - 15 degrees
      ); end cond & *cidmax*
    plinc 0 ; incrementer through selection set of Polylines
  ); end setq
  (initget "Retain Straighten")
  (setq
    arctemp
      (getkword
        (strcat
          "\nRetain or Straighten arc segments [R/S] <"
          (if *arcstr* (substr *arcstr* 1 1) "S"); at first use, S default; otherwise, prior choice
        ); end strcat
      ); end getkword
    *arcstr*
      (cond
        (arctemp); if User typed something, use it
        (*arcstr*); if Enter and there's a prior choice, keep that
        (T "Straighten"); otherwise [Enter on first use], Straighten
      ); end cond & *arcstr*
  ); end setq
  (prompt "\nSelect LWPolylines to put on a diet, or press Enter to select all: ")
  (cond
    ((setq plsel (ssget '((0 . "LWPOLYLINE"))))); user-selected Polylines
    ((setq plsel (ssget "X" (list '(0 . "LWPOLYLINE") (cons 410 (getvar 'ctab))))))
      ; all Polylines [in current space/tab only]
  ); end cond
  (repeat (sslength plsel)
    (setq pldata (entget (ssname plsel plinc)))
    (if (/= (cdr (last pldata)) (trans '(0 0 1) 1 0)); extr. direction not parallel current CS
        ; for correct angle & distance calculations [projected onto current construction
        ; plane], since 10-code entries for LWPolylines are only 2D points:
      (progn
        (command "_.ucs" "_new" "_object" (ssname plsel plinc)) ; set UCS to match object
        (setq ucschanged T) ; marker for *error* to reset UCS if routine doesn't
      ); end progn
    ); end if
    (setq
      front ; list of "front end" [pre-vertices] entries, minus entity names & handle
        (vl-remove-if
          '(lambda (x)
            (member (car x) '(-1 330 5 10 40 41 42 210))
          ); end lambda
          pldata
        ); end removal & front
      10to42 ; list of all code 10, 40, 41, 42 entries only
        (vl-remove-if-not
          '(lambda (x)
            (member (car x) '(10 40 41 42))
          ); end lambda
          pldata
        ); end removal & 10to42
      vinc (/ (length 10to42) 4); incrementer for vertices within each Polyline
      verts nil ; eliminate from previous Polyline [if any]
    ); end setq
    (if (= *arcstr* "Straighten")
      (progn
        (setq bulges ; find any bulge factors
          (vl-remove-if-not
            '(lambda (x)
              (and
                (= (car x) 42)
                (/= (cdr x) 0.0)
              ); end and
            ); end lambda
            10to42
          ); end removal & bulges
        ); end setq
        (foreach x bulges (setq 10to42 (subst '(42 . 0.0) x 10to42)))
          ; straighten all arc segments to line segments
      ); end progn
    ); end if
    (repeat vinc
      (setq
        verts ; sub-group list: separate list of four entries for each vertex
          (cons
            (list
              (nth (- (* vinc 4) 4) 10to42)
              (nth (- (* vinc 4) 3) 10to42)
              (nth (- (* vinc 4) 2) 10to42)
              (nth (1- (* vinc 4)) 10to42)
            ); end list
            verts
          ); end cons & verts
        vinc (1- vinc) ; will be 0 at end
      ); end setq
    ); end repeat
    (while (nth (+ vinc 2) verts); still at least 2 more vertices
      (if
        (or ; only possible if chose to Retain arc segments
          (/= (cdr (assoc 42 (nth vinc verts))) 0.0); next segment is arc
          (/= (cdr (assoc 42 (nth (1+ vinc) verts))) 0.0); following segment is arc
        ); end or
        (setq vinc (1+ vinc)); then - don't straighten from here; move to next
        (progn ; else - analyze from current vertex
          (setq
            vert1 (cdar (nth vinc verts)) ; point-list location of current vertex
            vert2 (cdar (nth (1+ vinc) verts)); of next one
            vert3 (cdar (nth (+ vinc 2) verts)); of one after that
            ang1 (angle vert1 vert2)
            ang2 (angle vert2 vert3)
          ); end setq
          (if
            (or
              (equal ang1 ang2 0.0001); collinear, ignoring distance
              (and
                (<= (distance vert1 vert3) *distmax*)
                  ; straightens if direct distance from current vertex to two vertices later is
                  ; less than or equal to maximum; if preferred to compare distance along
                  ; Polyline through intermediate vertex, replace above line with this:
                  ; (<= (+ (distance vert1 vert2) (distance vert2 vert3)) *distmax*)
                  (if (> (abs (- ang1 ang2)) pi); if difference > 180 degrees
                    (+ (min ang1 ang2) (- (* pi 2) (max ang1 ang2)))
                      ; then - compensate for change in direction crossing 0 degrees
                    (abs (- ang1 ang2)); else - size of difference
                  ); end if
                  *cidmax*
                ); end <=
              ); end and
            ); end or
            (setq verts (vl-remove (nth (1+ vinc) verts) verts))
              ; then - remove next vertext, stay at current vertex for next comparison
            (setq vinc (1+ vinc)); else - leave next vertex, move to it as new base
          ); end if - distance & change in direction analysis
        ); end progn - line segments
      ); end if - arc segment check
    ); end while - working through vertices
    (setq
      front (subst (cons 90 (length verts)) (assoc 90 front) front)
        ; update quantity of vertices for front end
      10to42 nil ; clear original set
    ); end setq
    (foreach x verts (setq 10to42 (append 10to42 x)))
      ; un-group four-list vertex sub-lists back to one list of all 10, 40, 41, 42 entries
    (setq pldata (append front 10to42 (list (last pldata))))
      ; put front end, vertex entries and extrusion direction back together
    (entmake pldata)
    (entdel (ssname plsel plinc)); remove original
    (setq plinc (1+ plinc)); go on to next Polyline
    (if ucschanged
      (progn
        (setq ucschanged nil) ; eliminate UCS reset in *error* since routine did it already
      ); end progn
    ); end if - UCS reset
  ); end repeat - stepping through set of Polylines
); end defun - PLD
(prompt "\nType PLD to put PolyLines on a Diet.")
Re: Lisp for Reducing vertices in polyline
Posted: Wed Mar 06, 2024 3:36 am
by Precious
This code is really helpful. Can you please update the code to make sure the straighten new polyline doesn't go into the previous polyline we are trying to straighten but rather the new polyline should do a check to make sure all the new point are outside the old polyline.
