  4. AutoLisp/SDS
Lisp routine and space as enter command
  4. AutoLisp/SDS
CMS Inc
Site Admin
Wed Feb 23, 2005 12:01 am
Azle, TX
  • Facebook
  • Twitter
  • YouTube
#1 by CMS Inc
CMS IntelliCAD has a system variable called SPACEASENTER.
Set it to 1 at the CMS IntelliCAD command bar and the Lisp script should work.
  • Tue Oct 15, 2019 9:51 am
Return to “AutoLisp/SDS”
  • It is currently Sun Oct 11, 2026 5:19 pm
