perimeter
New to IntelliCAD? Get started here with basic questions and answers.
Moderators: CMS Inc, avaernes
libomcad
perimeter
Post by libomcad » Thu Oct 10, 2019 4:09 am
Hello
Please how do I measure the perimeter (length of all lines)
Zdenko
sln8458
Re: perimeter
Post by sln8458 » Fri Oct 11, 2019 9:03 am
Hi Zdenko,
There is not a 'perimeter' command, however if your object is a circle/closed polyline/closed shape then if you select the object and then use the 'list' command this will give you the perimeter.
hth
libomcad
Re: perimeter
Post by libomcad » Sun Oct 13, 2019 10:49 pm
Thank you for your answer but command "list" doesn t exist
libomcad
Re: perimeter
Post by libomcad » Mon Oct 14, 2019 12:38 am
Komentár 2019-10-14 083323.jpg (7.9 KiB) Viewed 20 times
for example for example, picture - total line length
sln8458
Re: perimeter
Post by sln8458 » Mon Oct 14, 2019 2:40 am
Hi Zdenko,
the perimeter of your object needs to be drawn with a Polyline.
then using the List command (type - list entity information - into the search bar in the help section)
Your should get something like this:
