Change all fonts
mmiat
Wed Feb 20, 2019 7:09 am
Change all fonts
#1 by mmiat
Hi
my colleague has many drawings that gas text with different non-standard fonts, I'd like to change all to arial, is it possible to do automatically?
thanks
  • Fri May 24, 2019 1:20 am
  • It is currently Sun Oct 11, 2026 7:37 am
