... in R9.1
Hi!
the stretch command does not work after a short time working with the file. have to reload the file.
best regards.
Re: stretch in R9.1
We should have a fix soon. Please check for an update at the CMS IntelliCAD HELP menu > Check for updates feature.
Please make sure to uninstall 9.1 version, reboot your system and only then install the CMS IntelliCAD update.
Re: ... in R9.1
Please detail the steps to reproduce your report.
Copy, move, stretch have also command alias like "cp", "m" and "s" respectively.
While executing these commands you can move the mouse in the desired direction and then insert the displacement numeric value. Or, you can use also relative coordinates from a selected point to @ relative coordinate.
