Unable to RECOVER this drawing
General topics relating to CMS IntelliCAD.
kix
Post by kix » Mon Nov 05, 2018 1:40 am
Is it normal for Intellicad to make corrupted files (.dwg and .bak) without possibilities to recover?
Intellicad 8.4 version made corrupted files (.dwg and .bak) sometimes without possibilities to recover. Saving process look like without problem, but I could now just next time, when I open same file.
I had lot of files without possibilities to recover after upgrade to Intellicad 9.0 with settings: save in default format Autocad 2018 and incremental save enabled.
For better result I made some changes in settings: default format Autocad 2013 and incremental save disabled.
When open corrupted file:
1st dialogbox
Error: .dwg file needs recovery.
Unable to open this drawing.
It contains incorrect or corrupt information.
The RECOVER command may be able to extract undamaged information from this drawing.
2nd dialogbox
After RECOVER:>
Error: Object was erased.
Unable to RECOVER this drawing.
It contains incorrect or corrupt information that is too extensive for repair.
sln8458
Re: Unable to RECOVER this drawing
Post by sln8458 » Mon Nov 05, 2018 2:04 am
Hi
Do you still have 8.4 installed?
If you do try DFXOUT. I have found that creating a dxf file and the opening that in a new version will often solve an issue. should not be necessary but worth a try.
The next option would be to post a copy of a sample file and I will try on an older version I still have on an old laptop.
kix
Post by kix » Mon Nov 05, 2018 10:20 am
Hi.
Thank you for help. I found solution for now - I start again from scratch (put information together from additional files and from hard copy), and I restore some files from backup on external disc also…
That problem happen on Intellicad 9 with default format Acad 2018 and partial saving. I was trying to open with Autodesk DWG TrueView and without success. I was trying with DWG analyze tools and without success.
At first, I think – good to use partial saving. Now – better to use default format as Acad 2013 or 2010 in saving settings.
Kaspars
sln8458
Post by sln8458 » Tue Nov 06, 2018 2:38 am
Hi
Glad you got it sorted out.
I use 9 also, but have it set to save as Acad10, as this is used by one of my clients. So far I have not had any issues with corrupt files.
CMS Inc
Site Admin
Post by CMS Inc » Thu Feb 14, 2019 5:40 am
When opening a .dwg file that may have objects or blocks created in otherCAD it's recommended to run the AUDIT command and fix the issues that are presented.
mmiat
Contributor
Post by mmiat » Mon May 13, 2019 6:22 am
I've similar problem, icad 9.1 hangs during save and file is corrupted
I've also disabled autosave because it corrupted my file.
the file format is setted to "autocad 2004", how to set "partial saving"?
mmiat
Contributor
Post by mmiat » Fri May 24, 2019 1:22 am
after upgrading manually (*) intel rapid storage and intel management engine no more corrupted saved file since 10 days
(*) manually means not using windows update, but looking for driver in intel website and add it manually, forcing installation
mmiat
Contributor
Post by mmiat » Tue May 28, 2019 3:53 am
bad news, this morning it has hanged again during saving
however, saved file seems ok
