Image Disappearing
mapcon col
mapcon col
Sun Dec 06, 2015 10:36 pm
Image Disappearing
#1 by mapcon col
I have a jpeg2000 image in a drawing. Whenever the drawing auto saves or I select a manual save the image disappears. The box outline is still there but I cannot see the image. I have to close the drawing and open it again.
Anyone else come across this?
  • Wed Jun 22, 2016 4:47 pm
  • It is currently Sun Oct 11, 2026 12:14 pm
