upgrading WIN 10
slit_ok
slit_ok
Tue Sep 09, 2014 1:21 am
upgrading WIN 10
#1 by slit_ok
Hi!
do I need when upgrading WIN 10 to give the deactivation code?
thank you
  • Tue Sep 15, 2015 1:39 pm
CMS Inc
Site Admin
Wed Feb 23, 2005 12:01 am
Azle, TX
  • Facebook
  • Twitter
  • YouTube
#2 by CMS Inc
Before running the Windows upgrade, you need to deactivate the CMS IntelliCAD license.
Deactivation instructions can be found at the https://intellicadms.com downloads section
Failing to do so, will require a support pack purchase.
  • Tue Oct 13, 2015 5:18 am
  • It is currently Sun Oct 11, 2026 3:05 am
