QLEADER compatibility between intellicad and autocad
In autocad, I wrote an Autolisp script that drew a leader with two points. It was able to draw with two points since you could specify in the QLEADER settings how many points was needed to draw a leader. I cannot find any LEADER settings in intellicad and the QLEADER command does not work. Can someone please specify where the leader settings are or a workaround? Thank you in advance.
