Getting Application handle
Kalaiarasi
Kalaiarasi
Sat Mar 31, 2012 4:13 am
#1 by Kalaiarasi
In Intellicad6.6, Is it possible to get IAcadApplication (using DwgDirectX) object in a c++ application. If possible can anyone suggest a solution.
  • Thu Jun 21, 2012 12:26 am
  • It is currently Sun Oct 11, 2026 12:11 pm
