Adeko images not displayed after upgrade
Had this same issue with upgrade to 6.6, and 7.0. After upgrade, the Adeko raster images attached to a drawing are not displayed. Image manager has entries for the images, including good paths. Turning the frames on or off has no effect. Previously I deleted all the attached images and reattached the images, but that's a lot of work to scale and position the images.
Is there a drawing setting that needs changing, or something? Should that not be default?
In Intellicad help, check the text of TRANSPARENCY", the directions are "ON" and "ON".
What a bummer. :( :(
16 days, and no replies.
This wasn't urgent when I first posted, but it's getting there. One of the things I commonly do, is scan a diagram, say the pin-out for a electronic chip or component, insert the JPG image, and then draw circuits to the pins. The pin descriptions are there already, nice and neat. Now I have circuits with no images. :(
Not informing of fixes in a upgrade!
After posting the previous reply, I was surfing the other messages on this forum, and found a tech. support reply to download and install a later build. Hoping for a lucky result, I did that, and installed 7.0.4326.0.P, which solved my problem.
My issue, is 2 items:
1: There was no notification either by E-mail, or other, including a reply to my posting, where others could benefit.
2: The first message of this section of the forum is notifying of version 6.2... being available, which is ancient. This should be saying a later build is available, and here are the major items changed.
I generally opt out of most E-mail notifications, and may have opted out of something that would have made a difference. But maybe that classification is too broad, and a narrower classification added, or maybe I just misinterpreted the definition. :~)
