HP Officejet 7000 printer problems
I have a new Officejet 7000 A3 printer which works fine except with Intellicad V6.6. If the printer driver is installed after Intellicad it will print one page before locking up Intellicad. If Intellicad is installed after the printer driver (V14) it locks up as soon as you try to print to the printer. My laser printer works fine with Intellicad. Win XP SP3. Seems like a driver issue, any suggestions?
I have now changed HP print processors from hpfpp02t RAW to hpfpp091 RAW. I can now print OK but if I save the drawing after printing, Intellicad freezes. HP have not been helpful yet.
Has anybody had similar problems? Could it be a printer emulation issue?
Jim
Just a couple of quick thoughts:
1: Assuming other software prints OK.
2: Is this USB or Wireless, or other? If wireless, is there interference causing issues. Can you temporarily go USB? IF USB or other, have you tried different cable.
3:The latest drivers are installed, and they are for the current operating system including SP's. Try an older version driver.
4: Does device manager show any problems, and can you print the test page from there?
5: Try printing to a file, then as a temporary workaround printing the file from Explorer or something. Have you tried printing to a PDF?
I have a HP5550 USB and Laserjet 4+ parallel that worked fine from day one.
