MikeC,
What you need to do is to collect the xdata that might be already stored in the object into arrays, add new data into that arrays (you will need to redimension the arrays before in order to be able to add new data to them) and then set the xdata to the object using those arrays.
Here is an example extracted from the program's help (with a few changes):
Sub AppendXData(ByVal AppName As String, ByVal DataType As Variant, ByVal DataToAppend As Variant)
'Get the entity:
Dim anObj As Object
Dim pt As IntelliCAD.Point
ActiveDocument.Utility.GetEntity anObj, pt, "Select an entity: "
'Get its xdata:
Dim xdataType As Variant
Dim xdataValue As Variant
anObj.GetXData AppName, xdataType, xdataValue
If (vbEmpty = VarType(xdataType)) Then
Dim tmp(0 To 0) As Integer
xdataType = tmp
ReDim xdataValue(0 To 0)
'The first item in the XData should be a 1001
'Code giving the app's name:
xdataType(0) = 1001
xdataValue(0) = AppName
'Redimension the XData arrays, preserving their contents:
ReDim Preserve xdataType(LBound(xdataType) _
To (UBound(xdataType) + 1))
ReDim Preserve xdataValue(LBound(xdataValue) _
To (UBound(xdataValue) + 1))
'Set some new data:
xdataType(UBound(xdataType)) = DataType
xdataValue(UBound(xdataValue)) = DataToAppend
'Store the data:
anObj.SetXData xdataType, xdataValue
Set anObj = Nothing
Then, if you need to add several xdata values to an object just do the following:
Call AppendXData("MIKEC", 1000, "First value!")
Call AppendXData("MIKEC", 1000, "Second value!")
Call AppendXData("MIKEC", 1000, "And so on...")
Hope this helps!
JCAMPOS
