You need to deactivate the machine where it was previously installed.
To deactivate CMS IntelliCAD 6.6 from the previous machine, please proceed as follows:
*** XP machines ***
Press Windows START button. The select "Run..." and write the word CMD, press [ENTER]
On the DOS window do the following:
Write: CD.. and press [ENTER]
Write: CD Programs and press [ENTER]
Write: CD CMS and press [ENTER]
Write (*): CD IntelliCAD 6.6 Professional (or Standard) and press [ENTER]
Write: icad /ACTCONTINUE
(Note: be sure to have a SPACE between"icad" and "/ACTCONTINUE")
*** VISTA / 7 machines ***
On the command input box write: icad /ACTCONTINUE
Select the "Activate CMS IntelliCAD" , then "Phone registration" and then "Continue".
Send us the user codes 1, 2, and License ID number to
register@etoolbox.com requesting the deactivation of the license.
We will send you a registration code 1. After executing the same deactivation process (described above) insert it, and you will see a deactivation code. Send it finally to
