  4. New User
Fixed Ex. line
  4. New User
DurkDijkstra
DurkDijkstra
Sat Jan 23, 2010 9:32 am
Fixed Ex. line
#1 by DurkDijkstra
I have problems whit the settings of the dimensions. The funcions on tablet "Reserved" gives the option to set the "Fixed Ex. Line" on. But when i fix this option to "on" makes no difference. Working whit Autocad gives you nice short lines.
can anyone help me to fix this problem?
thanx for helping me.
  • Sat Jan 23, 2010 9:54 am
Return to “New User”
  • It is currently Sun Oct 11, 2026 7:17 pm
