Limits Bug in V6.6
I just installed and activated V6.6 on a PC with Windows XP SP3. I downloaded it from your website.
When I open Drawing Settings, click on the Coordinate Input tab, go to Change settings for: Limits, and then click on the Select > button, the program crashes. It does not matter if Disallow input beyond limits was unchecked or checked.
I tried with a blank drawing, old drawing, and had a friend who purchased it try it and the results were the same. I tried repairing it in control panel with no luck either.
PCSPHK,
I tried that with my CMS IntelliCAD 6.6 PRO and it worked properly. I must say that I tried also in 2 different PCs with both Windows XP SP3. No problems in both.
JCAMPOS
PCSPHK,
Ok, I tried the STD version in one PC with XP PRO SP2 and in other PC with XP PRO SP3 and once again it worked as expected. No problems at all.
JCAMPOS
