Entity Properties Toolbar
Hi All,
I would like to know how I can have the extended properties toolbar back.
When customizing I allways finish having just the edit layers and the set layers by entity, and the others fields, as the ability of changing, freezing and locking, and so on are vanished. sometimes I can managed to take it back but I cannot figure out how to.
thanks
Nico
nicolino,
Toolbar information is stored in the Windows Registry and can become corupted when customizing.
Warning: Using the method below will reset all customizing you have done to the installed default menus and toolbars etc. Backup all customizing prior to using reset.
You can reset the toolbars by selecting Tools-->Customize from the pull down menu.
Select the toolbar tab and select the "Reset" button.
This should reset the registry settings.
