Snaps on blocks?
Alosius
Alosius
Thu Sep 27, 2001 11:01 pm
Sevilla, España
Snaps on blocks?
#1 by Alosius
I've found that snaps don't work on blocks: I mean I cannot select midpoint on an entity belonging to a block.
Anyone knows how to do it, or it is not possible?
  • Sun Nov 04, 2001 5:53 am
tooldesigner
tooldesigner
Sun Aug 12, 2001 11:01 pm
#2 by tooldesigner
What version of intellicad are you running ?? I am running 2001 and I have no problem with snaping to block entities.
  • Sun Nov 04, 2001 6:51 pm
Alosius
Alosius
Sevilla, España
#3 by Alosius
I'm just trying the free demo version dated 3-19-2001.
  • Mon Nov 05, 2001 5:42 am
  • It is currently Sun Oct 11, 2026 6:34 am
