solids
EDUARDO DE-IRISARRI
EDUARDO DE-IRISARRI
Sun Sep 02, 2001 11:01 pm
BOGOTA, D.C., COLOMBIA
solids
#1 by EDUARDO DE-IRISARRI
Can something be done to have Intellicad read solids in the same way AUTOCAD does? When I open an Autocad v.12 drawing with solids drawn, Intellicad changes the figures and draws them criss-crossed?
  • Thu Oct 04, 2001 8:29 pm
  • It is currently Sun Oct 11, 2026 5:33 am
