  4. New User
Attributes in blocks
  4. New User
sathish
sathish
Wed Nov 09, 2005 12:01 am
India
#1 by sathish
Using VBA i have inserted the drawing as block in a new drawing. But it does not asks me to enter the value rather it takes the default value.
I have used the insertblock method alone in vba coding.
S.Sathish Kumar.
  • Fri Dec 02, 2005 2:38 am
Return to “New User”
  • It is currently Sun Oct 11, 2026 8:27 pm
