Is it possible to lock the paperspace viewport after setting the scale - so that zooming in model space does not change the scale?
thanks!
Lock the paperspace viewport?
- Newbie
- Valued Contributor
There's model space with tilemode on and with tilemode off. "On" is the state when Icad starts, "off" is when you work inside a paperspace viewport - that's only good for minimal editing and zooming and panning to the desired view.
The view in modelspace (tilemode on) should not effect any papperspace views.
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by davep:
AutoCAD will allow you to "lock" the display of the viewport. I do not see a way to do it in IntelliCAD.<HR></BLOCKQUOTE>
No, there is not a way to lock viewports in Icad but I really don't see why it would be needed. It takes quite a deliberate action to change to floating model space that if you did it, it's unlikely to be an accident.
