  4. New User
Xref Manager "not recognized"?
  4. New User
Zonex
Zonex
Fri Jun 24, 2005 11:01 pm
#1 by Zonex
Only been working with the application a few hours, and I already have two questions (see other posting). When I try to open the Xref Manager, I get a "command not recognized" response. I am certain I am in the Advanced user mode. Any ideas? Do I need to load some plug-in? Thanks!
  • Sat Jun 25, 2005 10:49 am
Return to “New User”
  • It is currently Sun Oct 11, 2026 7:53 pm
