  4. VBA, . NET & IRX
Offset
  4. VBA, . NET & IRX
  • 1
  • 2
Yolanda
Yolanda
Tue Jun 11, 2002 11:01 pm
Spain
#16 by Yolanda
Jack, could you send me your routine?. It seems like I have more problems offseting polilines than you, but I will try.
Thank you very much.
  • Wed Nov 13, 2002 3:56 am
  • 1
  • 2
Return to “VBA, . NET & IRX”
  • It is currently Sun Oct 11, 2026 2:11 am
