#19
Hi Martin,
I created a new toolbar ( L6_FTE ) then added a new tool (L6)
In the new tool, under command name I added
^C^C^C-layer;M;FTE;C;30;;;;
This works, in that it creates the new layer FTE, set the colour to 30 and then sets layer FTE to be the active layer.
There are 3 cancels (^C) as if you are in dimensions when you select the tool you could be 3 levels into the dimension command.
Plus a couple of ecxtra 'enters' to close the command.
sln8458 on Wed Feb 25, 2026 11:34 am, edited 1 time in total.
- L6.png (78 KiB) Viewed 5416 times
