Page 2 of 2
Re: ROTATE3D command
Posted: Mon Feb 03, 2025 1:28 pm
by sanches
Hi again!
Well, I have explored a bit, and these are my findings:
ALIGN and UCS change+ROTATE work exactly the same, provided that:
- when you change UCS (set "Z axis" as you explained), you have to return to 2D view, and then ROTATE.
If you ROTATE from orthogonal view, you get this:
ALIGN vs ROTATE.jpg (5.91 KiB) Viewed 41476 times
(A MISTAKE!!!)
But, if you ROTATE from 2D view, you get correct rotation:
ALIGN vs ROTATE1.jpg (4.23 KiB) Viewed 41476 times
i.e.
ALIGN vs ROTATE1a.jpg (7.6 KiB) Viewed 41476 times
Nevertheless, when I work in 3D I like to do all commands from 3D view. Why? Because, if I work from 2D, I can not see all the lines, I don't know what am I clicking (front or a back line), and I often make mistakes. This is why I would always choose to avoid 2D commands in 3D space.
Therefore, I recommend using ALIGN UNTIL SOFTWARE DEVELOPERS FIX ROTATE3D+Reference!!!
Many regards to you all,
AleX
P.S. For some reason, I can not attach the DWG (ZIP) file. I will post it in following message, so everybody can check where the problem is.
by sanches
And here is the DWG file, as I promissed.
Posted: Mon Feb 03, 2025 6:13 pm
SPirou4D wrote: ↑
Mon Feb 03, 2025 9:53 am
First: creation of the new UCS :
1 : Order for UCS in red !
2nd : Definition of the rotation axe with the 3D rotation command:
2 : Order for rotation axe in bleu !
3st: creation of the reference angle with the reference parameter :
3 : Order for Reference of angle in green !
Thank you, Patrick.
Posted: Tue Feb 04, 2025 1:44 am
by SPirou4D
sanches wrote: ↑
I tested your file and my 3D rotation work fine too.
You must verify the perpendicularity of your green plan because I find a little difference.
Take attention to the contact' points between your plan and the side of rotation.
Draw a construction line as rotation axe and when you create the UCS, choose this line.
Posted: Tue Feb 04, 2025 2:38 am
by SPirou4D
Thank you, Patrick.
I hope you are fine Quan!
Best Regards.
Patrick
Posted: Tue Feb 04, 2025 11:41 am
by CMS Inc
Developers QA retested this specific feature and they claim it works similar to Autodesk AutoCAD.
Thank you for the feedback.
Posted: Tue Feb 04, 2025 1:22 pm
by SPirou4D
It is command ALIGN. It works both in 2D and 3D.
Please, Aleksandra could you explain how you use this ALIGN function because I use the Align button here:
2025-02-04 20 21 06.png (3.51 KiB) Viewed 41427 times
In fact in your video you don't make a rotation, just a slip, no?
Posted: Wed Feb 05, 2025 4:36 am
by sanches
CMS Inc wrote: ↑
Hi CMS Team!
Thank you for following us on this forum.
We tested the specific feature (Rotate3D+ Reference) and it DOES NOT WORK similar to Autodesk and we do not know how it works.
To resolve this issue, please ask software developers to respond to my initial query in this Topic:
"Could anyone assist me with the following queries?
- offered "Reference Angle" is 0 - what should I click?
- what does "second point" stand for?
- what does "new angle" stand for?"
Many regards,
Aleksandra
Posted: Wed Feb 05, 2025 5:03 am
by sanches
SPirou4D wrote: ↑
Hi Patrick!
I use CAD software as of '90s, so I TYPE commands with my left hand and I use mouse with my right.
I just typed "ALIGN". The plane did rotate, around green axis.
I never tried that in AutoCAD, I just saw this in one of the tutorials posted on CMS site.
ALIGN command does rotate, but you have to set "destination" points first. Just like any other command with REFERENCE points. You need a reference (destination) points defined, prior to rotation/align.
I hope this helped. Please, ask if you are still uncertain.
Many regards,
Alex
Posted: Wed Feb 05, 2025 5:35 am
by SPirou4D
Yes me too !
I hope this helped.
No
I tested what you explain but I can't in IntellliCAD v13.1 !
When I use firts 3Drotation I select the green plane and then the axe of rotation with 2 points
But there iof I type Align in command line I can't ???? because 3Drotation ask me References or click !
Posted: Wed Feb 05, 2025 6:06 am
by sanches
Hi Patrick...
"When I use firts 3Drotation I select the green plane and then the axe of rotation with 2 points"
Try to click the axis in following manner:
Each of two points that define axis click two times.
This way you "say" to the Software "keep these two points on axis, where they are"
And then click the point on the green plane ONCE, and then click ONCE the point on blue plane.
This way, you did rotation around one side of the green plane, i.e. the axis.
Please let me know if you succeeded.
Alex
P.S. I use IntelliCAD 13.1 as well.
This ALIGN function is similar to ROTATE3D+Reference, and it is a little bit more complicated (you need to prepare some additional auxiliary lines and it requires more clicking!), but we can use it until CMS Team decides to share the information with us on how ROTATE3D command actually works.
Posted: Wed Feb 05, 2025 6:50 am
by SPirou4D
Ha YES you use ALIGN as rotation ! You don't use ALIGN and 3DROTATION both.
ok i did it
Same as this vid
https://www.intellicadms.com/download/f ... and-rotate
But this method is very very uncertain I mean !!! Because the axe of rotation there must be on the XY plane so that the first and second (origin/destination) couples are on this XY plane !
BUT when you are in space you must displace your UCS....
Posted: Wed Feb 05, 2025 8:36 am
by sanches
I fount this command here:
https://www.intellicadms.com/download/f ... 3d-editing
At 09:35...
I think it should be precise, but I will have to check a bit more (through practice)...
Posted: Wed Feb 05, 2025 11:03 am
by SPirou4D
Yes Aleksandra It's exactly the use of _ALIGN in 3D space and then _SUBTRACTION to cut shapes .
_ALIGN use 3 points to determine one plane (the first point is always the centering point et the rest of points are the pasting plane.
Posted: Tue May 06, 2025 12:59 am
by sanches
Hello everybody!
Let me just remind you that developers fixed the SLICE command, which is a great news for us architects, but ROTATE3D is still not working.
This is a kind reminder to Developers to address this issue as well.
(Even though there is a workaround with ALIGN command, it is still not the same... ROTATATE3D requires less steps and drawing to do the same task.)
Again, I have to publicly apologize to Developers for being so annoying (!) and to thank you guys (users) for solidarity and active involvement.
