For those who use Intellicad off-line just a warning on upgrading your system.
Intellicad is VERY twitchy to changes in the PC. A new hard drive or CPU or motherboard will flag the software as un-registered and prevent you from running the software. In some cases the software will ask for a new registration ID which you can purchase a new support pack to unlock or if you have an activation left on your license you can use that. In the case of a new CPU, it requires you to go on-line to re-make the ID and does not even ask for a new activation ID. I was completely blocked from using the software unless I went on-line to remake the ID.
You will undoubtedly note that Intellicad will let you TRANSFER your license from an existing system to a new system but upgrades or repairs to the same system cannot be done this way.
Support was very un-kind in stating that you must deactivate your license before upgrading and would not acknowledge that you can't do that off-line. No solution was offered to do this off-line at all and I was left hanging with my software not running.
So be very aware that once you install intellicad off-line your are stuck with that system as-built unless you go on-line and deactivate the license before you change anything. Depending on the upgrade, you still may have to go on-line to get it going again after the change.
Not ideal at all and definitely not documented so I wanted to warn others of this problem.
Re: OFFLINE UPGRADE - WARNING!!!
#2Users just need to remember to deactivate the license BEFORE making changes to the system.
License deactivation instructions, also supporting offline systems, are available at the download section of https://intellicadms.com
#3This is exactly the wall I ran into. You cannot deactivate your system off-line. You can only Transfer. They will not acknowledge this.CMS Inc wrote: ↑Mon Dec 06, 2021 5:40 amUsers just need to remember to deactivate the license BEFORE making changes to the system.
