Plotting arcs/Curves
I am having trouble plotting curved lines from Intellicad. Without selecting and regenerating a curve the plot is made up of a series of chords around the curve. Is there a better way to do this.
I am running v4 on Win 98.
Rowlo
Type Regenauto at the command line.
It should ask you if you want fast zooms?
Select Y for yes
Now type in the number say 200
You can try this with differing numbers.
This should fix the problem.
