GRIPOBJLIMIT - GRIPS ARE DISABLE
mvm.sartori
mvm.sartori
Tue Sep 28, 2021 2:09 am
#1 by mvm.sartori
SINCE LAST UPDATE WHEN I SELECT THE OBJECTS APPEARS: "SELECTION SET COUNT EXCEEDS GRIPOBJLIMIT. GRIPS ARE DISABLE"!!!
HOW CAN I SOLVE? HOW CAN I CHANGE GRIPOBJLIMIT? HOW CAN I ENABLE THE GRIPS?
THANKS
GREETINGS
  • Tue Sep 28, 2021 2:32 am
sln8458
Mon May 19, 2003 11:01 pm
Re: GRIPOBJLIMIT - GRIPS ARE DISABLE
#2 by sln8458
at the command prompt:
SETVAR (enter)
GRIPOBJLIMIT (enter)
type the value you have decided on, between 0 - 32767 (enter)
  • Tue Sep 28, 2021 6:54 am
mvm.sartori
mvm.sartori
#3 by mvm.sartori
Great!!! Thank you very much SteveN
best regards
Marco
  • Wed Sep 29, 2021 2:56 am
Designer_Ryan
Mon Jun 06, 2022 12:35 pm
#4 by Designer_Ryan
sln8458 wrote: ↑
SETVAR (enter)
Thanks, this helped me.
Ryan
10.1.1267.130525.PE.VC16.x64.CMS101a
  • Tue Jul 12, 2022 5:13 pm
SPirou4D
SPirou4D
Thu Apr 08, 2021 3:16 am
#5 by SPirou4D
sln8458 wrote: ↑
SETVAR (enter)
Thanks you so much for your great knowledge of CMS IntelliCAD, I discover always....
Patrick
  • Wed Jul 13, 2022 11:16 am
Artisan with cms 15
  • It is currently Sun Oct 11, 2026 4:46 am
