sld Convertor
Earthshaker77
Earthshaker77
Sat Feb 01, 2003 12:01 am
sld Convertor
#1 by Earthshaker77
I have seen reference to a jpg (and other)
format converter that converts other image types to sld files, but I can't find the software any one know where to find such a thing.
  • Sun Feb 02, 2003 11:39 am
avaernes
avaernes
Wed Oct 04, 2000 11:01 pm
Oslo, Norway
#2 by avaernes
Try this link:
http://www.cadalog.com/shareware.php?pa ... lor=ffffcc
  • Sun Feb 02, 2003 1:03 pm
Artisan with cms 15
  • It is currently Sun Oct 11, 2026 2:10 am
