How to hide dimensions?
swalton00
swalton00
Tue Jun 15, 2021 8:26 am
#1 by swalton00
I would like to hide dimensions in certain views, especially when I'm working in 3D. I suspect there is an easy way to do that, but I just can't seem to find it.
  • Tue Jun 15, 2021 8:32 am
sln8458
Mon May 19, 2003 11:01 pm
Re: How to hide dimensions?
#2 by sln8458
If it were me I would have all my dimensions on specific named layers which I could turn on/off as required.
Normally I have only a single dimension layer, but no reason you can't have more just depends on your layer naming.
  • Wed Jun 16, 2021 7:50 am
Artisan with cms 15
  • It is currently Sun Oct 11, 2026 8:37 am
