Toolbar ?
Ok, i got the new version 3.3 and i have custom toolbars on my older version 3.1 that i want to copy over on several computers. I have tried using tools>custumize>toolbar>import/export but when import toolbar all icons show up different than what they are suppose to be. I have gone to registry and found the old toolbars I want to copy over but i can't figure out how to move them easily, copy and paste doesnt work in regedit (win98). Also, i have exported the toolbars in the registry to a text file in an attempt to import them back in but i can't seem to import them in the proper place for them to work. Anybody got any ideas ? Thanks
This is a follow up to my early post. I figured out a work around. When you use the tools>customize>toolbar tab> and import new custom toolbar, all the icons change to CUSTOM BUTTON 7, but all the command line statements are correct, to fix this, after you have the toolbar tab selected and the tool button selected, go to options button and then on right side button bitmaps, either type in button name or hit the box on the right and select if its a custom button you have created.
