Tool Palettes not working on CMS 10 PE plus
ron
ron
Sun Apr 11, 2021 4:58 pm
#1 by ron
I have one PC running CMS 10 PE plus trial and tool palettes work fine.
On another PC I am running a purchased 10 PE plus and tool palettes will not work.
How can I fix this???
  • Sun Apr 11, 2021 5:15 pm
QuanNguyen
Sat Nov 09, 2019 6:50 pm
Re: Tool Palettes not working on CMS 10 PE plus
#2 by QuanNguyen
Not sure what you mean about the issue.
- the tool palettes not display?
- or the commands in palettes not work?
Please refer to the below for more information.
- viewtopic.php?f=4&t=1583&p=4437&hilit=t ... 52e5#p4437
- viewtopic.php?f=1&t=1764&p=6587&hilit=t ... 52e5#p6587
  • Sun Apr 11, 2021 9:32 pm
ron
ron
#3 by ron
Tool Palettes not working on CMS 10 PE plus.
Commands are not working in the tool palettes or in the menus at the top of the screens.
Thanks for any help.
  • Mon Apr 12, 2021 8:00 am
CMS Inc
Site Admin
Wed Feb 23, 2005 12:01 am
Azle, TX
  • Facebook
  • Twitter
  • YouTube
#4 by CMS Inc
In this case, make sure you have only the CMS IntelliCAD licensed edition installed and then proceed as follows:
1) close CMS IntelliCAD;
2) delete C:\Users\<user>\Documents\CMS IntelliCAD10.0x64;
3) restart CMS IntelliCAD;
  • Mon Apr 12, 2021 10:34 am
Hi i&#039;m an updater from v12.1 and had to uninstall v15 (manteinance updated) and run back to v12.1 cause with v15 it
Artisan with cms 15
I installed maintenance build 15.0.587.175583.PE+.VC17.x64.CMS150, but the problem persists; it doesn&#039;t happen cons
  • It is currently Sun Oct 11, 2026 11:05 am
