CMS IntelliCAD © PE Easy Run is currently in use - Error notice at turbo.net
If you're getting a CMS IntelliCAD © PE Easy Run is currently in use. Please try again and pass a different installation name using -name error notice when attempting to run CMS IntelliCAD © PE Easy Run, please proceed ad follows:
1. Run a Windows command prompt by running a Windows search for "cmd";
2. at the command prompt run command turbo login and insert your license credentials when prompted;
3. run command turbo uninstalli cms/intellicad
4. run command turbo uninstalli -a
5. now sign in to https://run.intellicadms.com
6. right mouse clock on top of the CMS IntelliCAD © PE Easy Run icon and select "Install on My PC"
7. Go to your Windows desktop and click on top of the CMS IntelliCAD © PE Easy Run icon;
8. CMS IntelliCAD © PE Easy Run should now run properly;
