XRef disappear
1 post
DenisSilveira
DenisSilveira
Sun May 24, 2020 8:22 am
XRef disappear
#1 by DenisSilveira
After attaching a a file inside drawing, moving screen makes the xref disappear from screen.
Needs to regen after every operation to "re-show" and exhibits again xref on screen.
Save and exit, reopen, continues the problem.
version 10.0.1461.118133.PE+.VC15.x64.CMS100a
  • Thu Feb 18, 2021 6:30 am
1 post
Artisan with cms 15
  • It is currently Sun Oct 11, 2026 8:07 am
