I have a problem with V10.0 of IntelliCAD.
When I draw lines, polylines, rectangles, arcs, etc I cannot see the entities like its turn off.
Only the circles can be seen.
This problem exists with both a new design and an existing design.
For example I open an existing drawing and it shows the Hatches but not the contour lines.
If I open the same file with Intellicad version 9 everything works fine.
But the lines exist: infact if I select them I can see the lins selected.
In the image below in a new drawing I have lines but they not seen. If I select the lines I can see that they are present.
Somebody would suggest me what happened.
LINE-POLYLINE-RECTANGLE INVISIBLE
#1- Attachments
- 1.jpg (115.47 KiB) Viewed 29085 times
- 2.jpg (137.85 KiB) Viewed 29085 times
