  4. VBA, . NET & IRX
Turn on and off ESNAP from .Net
  4. VBA, . NET & IRX
geza.szabo
geza.szabo
Contributor
Sun Dec 08, 2019 10:51 pm
#1 by geza.szabo
Is it possible to turn on and off entity snapping using the .net api? Can not find the documentation on this.
Kind regards
Geza
  • Mon Jun 22, 2020 12:41 am
QuanNguyen
Sat Nov 09, 2019 6:50 pm
Re: Turn on and off ESNAP from .Net
#2 by QuanNguyen
Hi Geza,
To turn on or off the running snap, simply set the SNAPMODE system variable to 1 or 0.
Refer:
// Turn-off running snap
Application.SetSystemVariable("SNAPMODE", 0);
// Turn-on running snap
Application.SetSystemVariable("SNAPMODE", 1);
  • Mon Jun 22, 2020 1:39 am
geza.szabo
geza.szabo
Contributor
#3 by geza.szabo
Adding as reference to myself. To turn off entity snapping the OSMODE system variable must be set to 0
  • Sat Dec 19, 2020 4:57 am
Return to “VBA, . NET & IRX”
Artisan with cms 15
  • It is currently Sun Oct 11, 2026 3:37 am
