  4. VBA, . NET & IRX
StartUndoMark / SetUndoMark
  4. VBA, . NET & IRX
DenisSilveira
DenisSilveira
Sun May 24, 2020 8:22 am
#1 by DenisSilveira
Is that possible to create UNDO marks in .NET/Intellicad commands ?
  • Sun Nov 01, 2020 2:33 pm
QuanNguyen
Sat Nov 09, 2019 6:50 pm
Re: StartUndoMark / SetUndoMark
#2 by QuanNguyen
Tried to search in the "Developer Help" document but not found any functions as your point out ( StartUndoMark/SetUndoMark, set Window Focus, create a Toolbar) in the .NET API. It seems that IntelliCAD does not support that function now.
Regards.
  • Mon Nov 02, 2020 3:22 am
Return to “VBA, . NET & IRX”
Artisan with cms 15
  • It is currently Sun Oct 11, 2026 3:39 pm
