Re: DWG to PDF
The Page Setup is ok, I tried to use DWG to PDF.
The result is a black drawing in PDF file.
Other formats the result is a PLT file. In "Microsoft to PDF" the page size max is A4, and result file is also PLT.
Did I miss something ?
Version 9.2.
Re: DWG to PDF
Hi
90% of my work is A3 so the microsoft to pdf does what I need. However if I need larger formats I use PDFCreator:
See if you can get the correct paper size with this.
Oh, I couldn't read your image, blurred.
Steve
Re: DWG to PDF
Image is horrible !! The web page does not allow me to upload more resolution file size. Microsoft PDf dosn't allow me to add large print size. I usually print in A1 format.
I will try PDF Creator FREE to test. But all prints are black until now, with many printer machines.
It's really important to print PDF, it's crucial !!!
Re: DWG to PDF
sln8458 wrote: ↑
Mon Jun 01, 2020 9:02 am
Hi
Steve
Re: DWG to PDF
#11
DenisSilveira wrote: ↑
Mon Jun 01, 2020 11:24 am
sln8458 wrote: ↑
Hi
Steve
I had downloaded PDFCreator and looks fine. It worked. Only all other print machines does not.
Re: DWG to PDF
#13
sln8458 wrote: ↑
Tue Jun 02, 2020 1:13 am
Hi Denis,
Can you confirm that you can print at the size you need AND that the background is NOT black
Steve
Hi Steve.
YES, PDFCreator solves the problem and I can print out SI sizes AND is not background black. My problem is solved.
Other print machines doesn't work, ok.
Re: DWG to PDF
#14
Tue Jun 02, 2020 3:32 pm
Hi Steve.
Hi Denis,
That suggests to me that the problem (black background) is with the other printer setups,
Could you try to uninstall one of the printers on the PC and re-install?
The only other thought I had is in the 'monochrome.ctb' file.
You have a white background on your monitor and this may be causing the black background
Steve
Re: DWG to PDF
#15
sln8458 wrote: ↑
Wed Jun 03, 2020 12:33 am
Hi Steve.
Hi Denis,
Steve
Hi Steve.
I'll try reinstall one of them. But "Dwg to Pdf" can't be reinstalled.
I use .stb file and I tried to change color of background and also table colors turn white and black to see if results change. I doesn't.
File to print
Result
Config screen:
