Using of Ji MLeader
After looking for so many codes and suggestions, I decided tu debug my own code and build a Jig for MLeader with mirroring block object. Down below is my code running perfectly in VS19 x Intellicad 9.
Imports App = IntelliCAD.ApplicationServices.Application
Module JigLeader
Public Sub CreateLeader()
'' Get the current database
Dim acDoc As Document = App.DocumentManager.MdiActiveDocument
Dim acCurDb As Database = acDoc.Database
'' Start a transaction
Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
'' Open the Block table for read
Dim acBlkTbl As BlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, Teigha.DatabaseServices.OpenMode.ForRead)
'' Open the Block table record Model space for write
Dim acBlkTblRec As BlockTableRecord
acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), Teigha.DatabaseServices.OpenMode.ForWrite)
'' Create the leader
Using acLdr As Leader = New Leader()
acLdr.AppendVertex(New Point3d(0, 0, 0))
acLdr.AppendVertex(New Point3d(4, 4, 0))
acLdr.AppendVertex(New Point3d(4, 5, 0))
acLdr.HasArrowHead = True
'' Add the new object to Model space and the transaction
acBlkTblRec.AppendEntity(acLdr)
acTrans.AddNewlyCreatedDBObject(acLdr, True)
End Using
'' Commit the changes and dispose of the transaction
acTrans.Commit()
End Using
End Module
Namespace LeaderPlacement
Public Class MLeaderJig
Inherits EntityJig
Protected _start As Point3d, _end As Point3d
Private _index As Integer
Private _lineIndex As Integer
Protected _started As Boolean
Private _blkName As String
Private m_pts As Point3dCollection
'Private m_leaderIndex As Integer
'Private m_LeaderLineIndex As Integer
Private m_tempPoint As Point3d
Public Sub New(BlockContent As String, Start As Point3d)
MyBase.New(New MLeader())
m_pts = New Point3dCollection()
Dim ml As MLeader = GetEntity()
ml.SetDatabaseDefaults()
ml.ContentType = ContentType.BlockContent
ml.EnableDogleg = True
ml.EnableLanding = True
ml.LandingGap = 0
'_index = ml.AddLeader()
_lineIndex = -1
_started = False
_blkName = BlockContent
_start = Start
_end = Start
AddVertex()
' A fairly standard Sampler function
Protected Overrides Function Sampler(prompts As JigPrompts) As SamplerStatus
Dim opts As JigPromptPointOptions = New JigPromptPointOptions()
opts.UserInputControls = (UserInputControls.Accept3dCoordinates Or UserInputControls.NoNegativeResponseAccepted)
If m_pts.Count = 0 Then
opts.Message = vbLf & "Start point of multileader: "
opts.UseBasePoint = False
ElseIf m_pts.Count = 1 Then
opts.BasePoint = m_pts(m_pts.Count - 1)
opts.UseBasePoint = True
opts.Message = vbLf & "Specify multileader vertex: "
ElseIf m_pts.Count > 1 Then
'opts.UserInputControls = opts.UserInputControls Or UserInputControls.NullResponseAccepted 'UserInputControls.Accept3dCoordinates Or UserInputControls.GovernedByOrthoMode Or UserInputControls.GovernedByUCSDetect Or UserInputControls.UseBasePointElevation
opts.UserInputControls = (UserInputControls.AnyBlankTerminatesInput Or UserInputControls.NoNegativeResponseAccepted Or
UserInputControls.Accept3dCoordinates Or UserInputControls.AcceptMouseUpAsPoint Or UserInputControls.NullResponseAccepted Or UserInputControls.AcceptOtherInputString Or
UserInputControls.GovernedByUCSDetect Or UserInputControls.GovernedByOrthoMode Or UserInputControls.InitialBlankTerminatesInput Or UserInputControls.NoZeroResponseAccepted)
opts.SetMessageAndKeywords(vbLf & "Specify multileader vertex or : [End]", "End")
'opts.Message = vbLf & "Specify multileader vertex: "
Else
Return SamplerStatus.Cancel
Dim res As PromptPointResult = prompts.AcquirePoint(opts)
If _end = res.Value Then
Return SamplerStatus.NoChange
ElseIf res.Status = PromptStatus.OK Then
_end = res.Value
Return SamplerStatus.OK
End Function
Protected Overrides Function Update() As Boolean
Dim ml = DirectCast(Entity, MLeader)
If m_pts.Count > 0 Then
ml.SetLastVertex(_lineIndex, _end)
Dim _dl = New Vector3d(If(_end.X <= m_pts(m_pts.Count - 1).X, -1, 1), 0, 0)
Dim doglen As Double = ml.DoglegLength * IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.Cannoscale.DrawingUnits
Dim landgap As Double = ml.LandingGap
If _end.X <= m_pts(m_pts.Count - 1).X Then
ml.SetDogleg(_lineIndex, _dl)
ml.BlockPosition = _end + ((doglen + landgap) * _dl)
Else
ml.EnableDogleg = False
If Not _started Then
If _start.DistanceTo(_end) > Tolerance.[Global].EqualPoint Then
Dim doc As Document = App.DocumentManager.MdiActiveDocument
Dim db As Database = doc.Database
Dim ed As Editor = doc.Editor
Dim ocm = db.ObjectContextManager
Dim occ = ocm.GetContextCollection("ACDB_ANNOTATIONSCALES")
ml.AddContext(occ.CurrentContext)
Using Tx As Transaction = db.TransactionManager.StartTransaction
Dim table As BlockTable = Tx.GetObject(db.BlockTableId, Teigha.DatabaseServices.OpenMode.ForRead)
Dim model As BlockTableRecord = Tx.GetObject(table(BlockTableRecord.ModelSpace), Teigha.DatabaseServices.OpenMode.ForWrite)
If Not table.Has(_blkName) Then
ed.WriteMessage(String.Format("\nPrecisa definir o bloco {0}", _blkName))
Return False
ml.BlockContentId = table(_blkName)
'ml.BlockPosition = New Point3d(4, 2, 0)
Dim AttNumber As Integer = 0
Dim blkLeader As BlockTableRecord = TryCast(Tx.GetObject(ml.BlockContentId, Teigha.DatabaseServices.OpenMode.ForRead), BlockTableRecord)
Dim Transfo As Matrix3d = Matrix3d.Displacement(ml.BlockPosition.GetAsVector())
For Each blkEntId As ObjectId In blkLeader
Dim AttributeDef As AttributeDefinition = TryCast(Tx.GetObject(blkEntId, Teigha.DatabaseServices.OpenMode.ForRead), AttributeDefinition)
If AttributeDef IsNot Nothing Then
Dim AttributeRef As New AttributeReference()
AttributeRef.SetAttributeFromBlock(AttributeDef, Transfo)
AttributeRef.Position = AttributeDef.Position.TransformBy(Transfo)
Commit(AttributeRef)
ml.SetBlockAttribute(blkEntId, AttributeRef)
Next
Tx.Commit()
End Using
'AddVertex()
_started = True
Else
ml.Visible = True
'ml.SetLastVertex(_lineIndex, _end)
Return True
End Function
Public Sub AddVertex()
Dim ml As MLeader = TryCast(Entity, MLeader)
_lineIndex = ml.AddLeaderLine(_index)
ml.AddFirstVertex(_lineIndex, _start)
'ml.AddLastVertex(_lineIndex, _end)
Else
m_pts.Add(_end)
Public Sub RemoveLastVertex()
Dim dogvec As Vector3d = ml.GetDogleg(_index)
'If m_pts.Count >= 1 Then
If ml.GetLastVertex(_lineIndex).X <= ml.GetVertex(_lineIndex, ml.VerticesCount(_lineIndex) - 2).X Then
dogvec = New Vector3d(-1, 0, 0)
ml.BlockPosition = ml.GetLastVertex(_lineIndex) + ((doglen + landgap) * dogvec)
Else
dogvec = New Vector3d(1, 0, 0)
'End If
Public Function GetEntity() As Teigha.DatabaseServices.MLeader
Return TryCast(MyBase.Entity, Teigha.DatabaseServices.MLeader)
End Function
Public Overridable Sub Commit(AttributeRef As AttributeReference)
' nada aqui
'Select Case AttributeRef.Tag
' Case "MARCA"
' AttributeRef.TextString = _contents.Marca
' Case "QTD"
' AttributeRef.TextString = _contents.Qtde
' Case "TRATAMENTO"
' AttributeRef.TextString = _contents.Tratamento
' Case "DESCRICAO"
' AttributeRef.TextString = _contents.descricao
' Case "LISTA"
' AttributeRef.TextString = _contents.lista
'End Select
Public Sub MyMLeaderJig()
Dim doc As Document = IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
'Dim jig As MLeaderJig = New MLeaderJig("novo_ponto", CType(blockContent.Entity, DBPoint).Position)
Dim bSuccess As Boolean = True, bComplete As Boolean = False
While bSuccess AndAlso Not bComplete
Dim dragres As PromptResult = ed.Drag(Me)
bSuccess = (dragres.Status = PromptStatus.OK)
If bSuccess Then Me.AddVertex()
bComplete = (dragres.Status = PromptStatus.None)
If bComplete Then Me.RemoveLastVertex()
End While
If bComplete Then
Dim tr As Transaction = db.TransactionManager.StartTransaction()
Using tr
Dim bt As BlockTable = CType(tr.GetObject(db.BlockTableId, Teigha.DatabaseServices.OpenMode.ForRead, False), BlockTable)
Dim btr As BlockTableRecord = CType(tr.GetObject(bt(BlockTableRecord.ModelSpace), Teigha.DatabaseServices.OpenMode.ForWrite, False), BlockTableRecord)
btr.AppendEntity(Me.GetEntity())
tr.AddNewlyCreatedDBObject(Me.GetEntity(), True)
tr.Commit()
End Using
End Class
Public Class Leader
Inherits MLeaderJig
Protected blockContent As XPV
Public Sub New(PV As XPV)
MyBase.New("novo_ponto", CType(PV.Entity, DBPoint).Position)
blockContent = PV
' Store info that's passed in, but don't init the MLeader
Public Overrides Sub Commit(AttributeRef As AttributeReference)
Case Is = "PV"
AttributeRef.TextString = blockContent.PV
Case Is = "CT"
AttributeRef.TextString = blockContent.CT
Case Is = "CF"
AttributeRef.TextString = blockContent.CF
Case Is = "CTERRENO"
AttributeRef.TextString = blockContent.CTerreno
Case Is = "PON"
AttributeRef.TextString = blockContent.TAG
End Select
End Class
End Namespace
Re: Using of Ji MLeader
After L.MyMLeaderJig() the line L.ObjetId gets eNotOpenForRead.
Any idea how access objects/elements from inside classes after they had been created and added to BlockTableRecord via Transaction ?
Public Sub Cmd2()
' If ps Is Nothing Then
Try
While True
Using tx As Transaction = App.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction
Dim pso As New PromptSelectionOptions
pso.MessageForAdding = "Selecione>"
Dim psr As PromptSelectionResult = IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.GetSelection(pso)
If Not psr.Status = PromptStatus.OK Then Exit While
Dim PV As New XPV '(psr.Value(0).ObjectId)
PV.Entity = tx.GetObject(psr.Value(0).ObjectId, Teigha.DatabaseServices.OpenMode.ForRead)
PV.Retrieve()
Dim L As New Leader(PV)
L.MyMLeaderJig()
Dim id As ObjectId = L.ObjetId
Dim Xpvl As New XPVLeader
Xpvl.Entity = L.MLeaderEntity.ObjectId.GetObject(Teigha.DatabaseServices.OpenMode.ForRead)
Xpvl.EntityToHandle = PV.Entity.Handle
Xpvl.Commit()
tx.Commit()
End Using
End While
Catch ex As System.Exception
IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.ToString)
End Try
DenisSilveira wrote: ↑
Fri May 29, 2020 8:33 am
Module JigLeader
End Using
acTrans.Commit()
End Using
End Module
Inherits EntityJig
ml.LandingGap = 0
_lineIndex = -1
_started = False
_start = Start
_end = Start
AddVertex()
Else
_end = res.Value
End Function
Else
Return False
Next
Tx.Commit()
End Using
'AddVertex()
_started = True
Else
ml.Visible = True
Return True
End Function
Else
m_pts.Add(_end)
Else
'End If
End Function
' nada aqui
' Case "MARCA"
' Case "QTD"
' Case "TRATAMENTO"
' Case "DESCRICAO"
' Case "LISTA"
'End Select
End While
If bComplete Then
Using tr
tr.Commit()
End Using
End Class
Public Class Leader
Inherits MLeaderJig
blockContent = PV
Case Is = "PV"
Case Is = "CT"
Case Is = "CF"
Case Is = "PON"
End Select
End Class
End Namespace
The "L" is a class implemented by myself inherits Jig and doesn't have UpGradeOpen.
May I send file to you.
Imports IntelliCAD.ApplicationServices
Imports IntelliCAD.EditorInput
Imports Teigha.DatabaseServices
Imports Teigha.Geometry
        Inherits EntityJig
            ml.LandingGap = 0
            _lineIndex = -1
            _started = False
            _start = Start
            _end = Start
            AddVertex()
            Else
                _end = res.Value
        End Function
                Else
                            Return False
                        Next
                        Tx.Commit()
                    End Using
                    'AddVertex()
                    _started = True
            Else
                ml.Visible = True
            Return True
        End Function
            Else
            m_pts.Add(_end)
            Else
            'End If
            Return TryCast(MyBase.Entity, MLeader)
        End Function
        Property GetObjectId As ObjectId
            ' nada aqui
            '    Case "MARCA"
            '    Case "QTD"
            '    Case "TRATAMENTO"
            '    Case "DESCRICAO"
            '    Case "LISTA"
            'End Select
            End While
            If bComplete Then
                    GetObjectId = Me.GetEntity.ObjectId
                    tr.Commit()
                End Using
        Public Overloads Sub Dispose(A As Boolean)
            MyBase.Dispose(A)
            If Not m_pts.IsDisposed Then
                m_pts.Dispose()
    End Class
End Namespace
I don't have class XPV so try to create a new constructor for Leader class as below:
        Public Sub New()
            MyBase.New("novo_ponto", Point3d.Origin)
            blockContent = "blockContent"
call :
Dim L As New Leader()
then L.MyMLeaderJig() works, I mean that the program not get the exception"eNotOpenForRead".
I'll try that ... so post result here ... down is the code:
Public Class XPV
    Inherits XElement
    Public isPV As Boolean
    Public CT As Double
    Public CF As Double
    Public CTerreno As Double
    Public TAG As String
    Public PV As String
    Public Sub New()
        MyBase.New("AD PV Atributos")
        isPV = False
    Public Overloads Sub Commit()
        Try
            Rb = New ResultBuffer
            Rb.Add(New TypedValue(DxfCode.Real, CT))
            Rb.Add(New TypedValue(DxfCode.Real, CF))
            Rb.Add(New TypedValue(DxfCode.Real, CTerreno))
            Rb.Add(New TypedValue(DxfCode.Text, PV))
            Rb.Add(New TypedValue(DxfCode.Text, TAG))
            MyBase.Commit()
            isPV = True
        Catch ex As system.Exception
            App.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.ToString)
        End Try
    Public Overloads Sub Retrieve()
        Try
            MyBase.Retrieve()
            CT = Rb(0).value
            CF = Rb(1).value
            CTerreno = Rb(2).value
            PV = Rb(3).value
            TAG = Rb(4).value
            isPV = True
        End Try
End Class
Public MustInherit Class XElement
    Private vEntity As Entity
    Private entryName As String
    Property Rb As ResultBuffer
    Public Sub New(Name As String)
        entryName = Name
    Property Nome As String
        Get
            Return entryName
        End Get
        Set(value As String)
            entryName = value
        End Set
    End Property
    Property Entity As Entity
        Get
            Return vEntity
        End Get
        Set(value As Entity)
            vEntity = value
        End Set
    End Property
    Property Buffer As ResultBuffer
        Get
            Return Me.Rb
        End Get
        Set(value As ResultBuffer)
            Me.Rb = value
        End Set
    End Property
    Private Function GetXrecordData(ByVal id As ObjectId, tr As Transaction) As Xrecord
        Dim ret As Xrecord = Nothing
        Try
            'Using tr As Transaction = IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.TransactionManager.StartTransaction()
            Dim obj As DBObject = CType(tr.GetObject(id, Teigha.DatabaseServices.OpenMode.ForRead), DBObject)
                If obj.ExtensionDictionary = ObjectId.Null Then
                    Return Nothing
                Dim dict As DBDictionary = CType(tr.GetObject(obj.ExtensionDictionary, Teigha.DatabaseServices.OpenMode.ForRead), DBDictionary)
                If dict.Contains(entryName) Then
                    ret = tr.GetObject(dict.GetAt(entryName), Teigha.DatabaseServices.OpenMode.ForRead)
                Else
                    Return Nothing
            '   tr.Commit()
            'End Using
        Catch ex As Teigha.Runtime.Exception
            MsgBox(String.Format("{0} - {1} {2} {3}", System.Reflection.MethodBase.GetCurrentMethod().Name, ex.Source, ex.StackTrace, ex.Message), vbCritical)
        End Try
        Return ret
    End Function
    Public Sub Retrieve()
        Try
            Dim db = Intellicad.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database
            Rb = Nothing
            Using Lock = Intellicad.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument()
                Using tr = db.TransactionManager.StartTransaction()
                    Dim Xrec As Xrecord = GetXrecordData(vEntity.ObjectId, tr)
                    If Not IsNothing(Xrec) Then
                        For Each KeyPair In Xrec.Data
                            Rb.Add(New TypedValue(KeyPair.TypeCode, KeyPair.Value))
                        Next
                    Else
                        Rb = Nothing
                End Using
            End Using
        End Try
    Public Sub Commit()
        Try
            Using Intellicad.ApplicationServices.Application.DocumentManager.MdiActiveDocument.LockDocument()
                Using tr = vEntity.ObjectId.Database.TransactionManager.StartTransaction()
                    Dim obj As Entity = CType(tr.GetObject(vEntity.ObjectId, Teigha.DatabaseServices.OpenMode.ForRead), Entity)
                    Dim dictId As ObjectId = obj.ExtensionDictionary
                    If dictId.IsNull Then
                        obj.UpgradeOpen()
                        obj.CreateExtensionDictionary()
                        obj.DowngradeOpen()
                        dictId = obj.ExtensionDictionary
                    Dim dict As DBDictionary = tr.GetObject(dictId, Teigha.DatabaseServices.OpenMode.ForWrite)
                    Dim xrec As Xrecord
                        xrec = tr.GetObject(dict.GetAt(entryName), Teigha.DatabaseServices.OpenMode.ForWrite)
                    Else
                        xrec = New Xrecord()
                        dict.SetAt(entryName, xrec)
                        tr.AddNewlyCreatedDBObject(xrec, True)
                    xrec.Data = Rb
                    AddRegAppTableRecord(entryName)
                    Dim RbXdata As New ResultBuffer
                    RbXdata.Add(New TypedValue(DxfCode.ExtendedDataRegAppName, entryName))
                    RbXdata.Add(New TypedValue(DxfCode.ExtendedDataInteger16, 1))
                    vEntity.UpgradeOpen()
                    vEntity.XData = RbXdata
                    vEntity.DowngradeOpen()
                    tr.Commit()
                End Using
            End Using
        End Try
End Class
Look the problem not to initiate MLeader in Mybase.New because it belongs to EntityJig wich has the Entity as the constructors and the property Entity is ReadOnly.
So the only one moment to initiate is inside the constructor to jig it after.
        Inherits EntityJig
        Public Sub New(BlockContent As String)
            ml.LandingGap = 0
            _lineIndex = -1
            _started = False
            'AddVertex()
        Property Start As Point3d
            Get
                Return _start
            End Get
            Set(value As Point3d)
                _start = value
                _end = value
            End Set
        End Property
            Else
                _end = res.Value
        End Function
                Else
                            Return False
                        Next
                        Tx.Commit()
                    End Using
                    AddVertex()
                    _started = True
            Else
                ml.Visible = True
            Return True
        End Function
            Else
            m_pts.Add(_end)
            Else
            'End If
        End Function
            ' nada aqui
            '    Case "MARCA"
            '    Case "QTD"
            '    Case "TRATAMENTO"
            '    Case "DESCRICAO"
            '    Case "LISTA"
            'End Select
            End While
            If bComplete Then
                    tr.Commit()
                End Using
            MyBase.Dispose(A)
                m_pts.Dispose()
    End Class
End Namespace
